Bugger.
OH dear - BLOCKED OIL PICKUP - in 19,000klms - this may save your engine
Reminder - Injector port cleaning
Just a reminder how to clean the ports.
Originally posted by Anth120playdo View PostSome general information about blow by:
Blow by = in this case we are talking about the injector seating surface / gasket / head leak.
It's a leak of compression gasses up the injector port.
How to clean ports:
Special tool hardwood dowel from Bunnings.
Keep polishing & replacing rags till it looks like
Yes time consuming to do it right.
A top quality torque wrench like "warren & brown" to torque the injector clamps 22NM.
Yes I even torque the dummy injectors for the compression test.
NOW CONTINUED FROM POST 1.
The sheets/washers/seats, whatever you like to call them.
The oil o-ring which blows out & lets oil down
New & failed to compare
The cleaning ports, a port with blow by is lots of extra work
Getting better
