LED headlight conversion
  • LED headlight conversion
    Hi guys
    The other day I got my LED headlight conversion kit. I installed them
    As they are a plug and play. Tested them out all good low beam works fine but the highbeam doesn't seem to work. I done a few tests one of them was I unplugged the LED and connected the hologen globe, high beam worked fine and the other led globe high beam worked fine also. But when I connect the led back its back to square one again. Because of this my LED spotties don't work. Anyone on here who have experienced the same thing can you please lead me in the right direction. Cheers.
    LEDs have polarity.
    Which Prado have you got?
      LEDs have polarity.
      120 grande 07
        Originally posted by Htc prado View Post
        Hi guys
        I Have the same issue. Has anyone found a work around for this.
        My spotties are wired up to the switch via the high beam wire. This wire does NOT have power to it when a LED globe is plugged in. This is why the spotties no longer work.
          I'll take a guess and say it sounds like you need a load on the circuit eg when you replug halogen it works. If not this reply may regenerate some interest for you
          Cheers Brian. 2006 Grande D4D
