BFG Promo - buy 4 tyres, get free ARB air compressor
    Toyo AT2 has a 2 ply sidewall unlike BFG whichs are 3 ply side walls. 2 ply can flex better than a 3 ply but a 3 ply can hold more load than a 2ply.
      got mine fitted and sent of rego for compressor
      what to do with the compressor ??? ( i have endless air !!)
        I'm in a dilemma, - I need 5. I've got about 5k (easy) left on my BFG's (at nearly90k)
        But I love free stuff, got one of these compressors already, 4 years never missed a beat.
        I know I will be needing rubber for planned long trips early next year (may take that long to use 5k as well)
        Ummmm...Buy & not fit ? to get a new compressor, - wait & get later (hopefully get 10% cheaper at Bob's)
        All works out "about" the same (not quite).....Ahh, I need help to make a decision for me.
        SWMBO just says - your car, your choice....that is dangerous ground.
        Impatient, Ben
        2011 GX Blue Storm Auto D4D
        2" OME Lift, BFG AT's, Speedy Avalanche Wheels, ARB Bar, Safari Snorkle, Duel Batt Setup, TG150 Guard, TJM Side Steps, Tinted, Spotties, Draws, Rhino Platform, Recovery Points, Tin175 UBP.
          D4D's picture above shows very minimal balance weights used. If the tyre fitter does not align the yellow dot on the tyre with the valve stem, it would usually mean more weight is required. But if the yellow dot is aligned to the valve stem, then minimal weight is required.
          My mate (ex PP member) manages the tyre shop I bought them from and he fitted & balanced them. They all balanced up to 0:0 with minimum weights. I commented on the lack of weights, less than what was on my KOs, he said sometimes you get lucky.
          I prefer clip on weights as you can get a better balance and it is easier to get them to 0:0 as the weight is on the edges of the rim and not on the inside.
            My Tyrepower dealer said he can only do them for $365 each, that's $15 more than BJane quoted. He told me that any cheaper than that and they are old stock tyres..oh well will put it off for a while don't really need a compressor.
            [url]www.wickedphotos.com.au[/url]
              I think he's talking crap, mine are stamped 2316, which is week 23 year 2016, that would be the first week of June this year...
                i have sent you a PM Kandyg
                  Cheers Razor will give ya bell tomorrow, just out of interest are they the 121s or 112s ? I see the 112's are available on tyresales but not the 121's
                    these are the 121
                      I always wondered why 121 would be better than 112 - I mean 112 have load rating of 1100kg per tyre or so and since our GVM cannot exceed 3000 that should be more than enough? I might be missing something?
                        The load rating isn't just for static weight. It is for dynamic weight as well and those times when you lift the tyre off the ground. A 121 load rated tyre has more plies and is usually less prone to punctures and staking due to stronger sidewalls, etc.
                          Cheers Andrew Mine are 121/118S - I thought BFG LT rated tyres are the all 121 anyway - you learn something everyday
                            The 118 part is when you mount 2 wheels side-by-side.
                              off for another set tomorrow for the caravan
                                Make sure you use a different name/address for the invoice to make sure you get another compressor.
