Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Cool box fan
  1. #1
    Lurker
    Join Date
    Jan 2011
    Location
    Malvern East, VIC
    Posts
    10
    Cool box fan
    Does any-one know how to replace the Centre Console Cool Box fan in Prado120?
    Toyota want to remove the entire centre console just to replace the $80.00 fan. This takes 4 to 5 hours and means disconnecting the gas lines, and re-gassing on re-assembly.
    There must be a smarter way. Even if a bit of plastic has to be cut!!
    Paul
  2. #2
    Lurker
    Join Date
    Aug 2014
    Location
    perth w.a.
    Posts
    15
    Interested to know also as i have the same problem, is the fan only 80 bucks?
  3. #3
    Lurker
    Join Date
    Jan 2011
    Location
    Malvern East, VIC
    Posts
    10
    $79.99 to be exact, p/n88550-60120 Motor Assy, Blo J702 (That was from Toyota Spares and a small discount on RRP)
    Quote Originally Posted by quadrio View Post
  4. #4
    Lurker
    Join Date
    Aug 2014
    Location
    perth w.a.
    Posts
    15
    Im going to start pulling mine apart tomorrow will post up once i work out a better way
  5. #5
    Lurker
    Join Date
    Jan 2011
    Location
    Malvern East, VIC
    Posts
    10
    quadric, Did you have success getting the fan out? Paul
  6. #6
    Join Date
    May 2015
    Location
    Bendigo
    Posts
    377
    Im going to have to do the same thing I think.
    I haven't done a 120 before, but in previous instances cooler boxes are usually put in as a whole unit unfortunately.
  7. #7
    Any joy fellas?
    I've been putting this one off awhile as I can't figure out how to separate the cooler box...
  8. #8
    Join Date
    Apr 2007
    Location
    Sydney, NSW, Australia.
    Posts
    99
    Hi
    I replaced mine about four months ago. You reall need to take the entire console out in order to replace the fan. If you open up the console lid, you will notice there is a gasket. Peal the gasket off then you will see screws. You can peel if off carefully and reuse it if not you need to buy a new one. Once those screws are off, there is also screws on both right and left side of the console if you look at the rear AC controls.
    Once you have the console off, becareful with the AC pluming.
    Alan
    07 120 D4D Grande
  9. #9
    Lurker
    Join Date
    Jan 2011
    Location
    Malvern East, VIC
    Posts
    10
    Yes, fan replaced, but centre console needed to come out and A/C lines disconnected. As A/C had never been regassed, felt good idea. Done privately, 2.2 hours, less than half the time quoted by dealer.
    All done just in time for summer.
    Cheers Paul
  10. #10
    Lurker
    Join Date
    Aug 2014
    Location
    perth w.a.
    Posts
    15
    Can confirm a/c does not need to be touched, just finished putting mine in and left all a/c attached
  11. #11
    Member D4DDave's Avatar
    Join Date
    Jan 2013
    Location
    Canberra ACT
    Posts
    114
    Don't mean to hijack the thread, but I've also read the same (in the service manual) regarding the need to disconnect & re-gas the AC in order to perform the park brake cable adjustment in my 150. Surely there's an easier/cheaper way for something that's a relatively common maintenance task?
    David.
    2012 150 Series D4D Kakadu
    Wynnum Towbar, Narva Merit/USB/lighter sockets, Pirahna dual battery tray, Redarc BCDC1240, Xantrex LinkPro battery monitor, 600W inverter, ARB onboard air & WaterWatch on AMTS bracket, Phillips 35W HID high beams, UHF, Roadsafe front recovery points, Offroad Systems drawers with integrated water storage with tap concealed in rear tailgate, ARB 47L fridge.
  12. #12
    Am about to try and fix my fan anyone have any hints thanks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
