Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
  1. #13
    Join Date
    Sep 2011
    Location
    Hervey Bay
    Posts
    232
    Great post Anth 120
  2. #14
    Senior Member Killswitch's Avatar
    Join Date
    Jan 2015
    Location
    Perth
    Posts
    300
    Well this is on the list for the next service.
    Thanks Anth.
    [2007 GXL 120 3.0L D4D Auto] Mods: Bilstein Shocks & King 2" Lift Springs - 265/70/17 Cooper AT/3s Tyres - ARB Deluxe bullbar - LED Spotlights & Worklights - Snorkel - BushSkinz bash plates - 2.2m Alloy Overlander Full Rack - 2.5m Wanderer Awning - GME TX3120S UHF & GME AE4703 6.6dBi - Milford Cargo Barrier - JVC indash DVD - Maxtrax - Pulling a heavily modified Jayco Dove Pop Top Camper
  3. #15
    Join Date
    Jan 2015
    Location
    Perth
    Posts
    300
    Double Post. :P
  4. #16
    Join Date
    Jan 2015
    Location
    Perth
    Posts
    300
    I did mine on the weekend. Didnt look as bad as above but still had some crud on it. All cleaned up and back together. Thanks for the simple guide Anth.
  5. #17
    Lurker
    Join Date
    Jul 2017
    Location
    Perth, WA
    Posts
    2
    Sorry to bring up an older thread but does anyone happen to know if this process is the same for petrol vs diesel? Just bought a v6 petrol 120 and would like to add this check to each oil change I do in the future, as I recently had a blocked pick up cleaned by a mechanic and we all know their labour costs an arm and a leg. I searched in the petrol section of the page but couldn't find a similar thread so thought I'd try my luck here.
    Also any chance of new photo links? I can't get the photos to work due to Photobucket's new third party hosting fee..
  6. #18
    Water pistol pilot. Piggy's Avatar
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,795
    Blog Entries
    4
    V6 Drop the bash plates, drain the oil, Leave for a few hours or O'night. Look thru sump hole with a torch or borescope to see the screen. (Im not actually sure if you can see it on a v6 thru the drain plug hole however). Otherwise, remove the smaller sump section. Replace gasket or re-use if its in OK condition and some silicone (Grey Max or similar) to reseal it all.
  7. #19
    Lurker
    Join Date
    Jul 2017
    Location
    Perth, WA
    Posts
    2
    Quote Originally Posted by Piggy View Post
    Great thanks. If there is gunk on the pick up, I'll be able to clean it with just the smaller sump section removed?
  8. #20
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,795
    Blog Entries
    4
    The pickup is in the lowest point of the sump. So that would be a yes.
  9. #21
    Lurker matt18x's Avatar
    Join Date
    Dec 2011
    Location
    Central Coast NSW
    Posts
    6
    Thanks Anth 120 for info. Checked mine today to find it was severely blocked. I had asked mechanic to check it two times after injector seal issue a few months back. he said it was all good and that he checked it on both occasions. Just about to start an 8000km trip towing a van. Not sure how long it would have lasted based on the condition of the pick up.FullSizeRender-2.jpg
    2008 D4D 6sp Manual. Standard GXL. April '08 Build.
  10. #22
    Advanced Member OldGreyFart's Avatar
    Join Date
    Feb 2013
    Location
    Canberra
    Posts
    564
    Quote Originally Posted by matt18x View Post
    Luck to get a few km from your driveway looking like that.
    Terry
    Canberra
  11. #23
    Lurker
    Join Date
    Apr 2016
    Location
    Ulverstone, Tasmnaia, Australia
    Posts
    1
    I've been told that if you can see a build up of carbon on the oil pick up when inspecting it through the sump plug after draining the oil you car dissolve the carbon build up with few squirts of brake cleaner and there is no need to remove the sump.
    Has anyone tried this?
  12. #24
    Join Date
    Mar 2014
    Location
    Adelaide, SA
    Posts
    83
    Might work but do it properly to be sure the sump is clean.
    Remember you need to fix the cause..... leaking injector seals ,,, If you don’t fix the seals it just going to get worse and then bang.
    White 2010 gx diesel auto, bilstein shocks 50mm lift king springs, tjm steps, warn 9500, lt265-65-17 bfg atko on steel rims. Racor 230R10 filter
    Adelaide based
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
