Steve's 2016 150 GXL Rig Build
  • #46
    Originally posted by juz View Post
    Let us know how you go with the electrical connectors. I wasn't happy with them at all.
    They look and feel cheap - with some issues shown above..
    I'm still not sure if i needed to use the 10cm additional cable.
    • #47
      Originally posted by steve.armitage View Post
      Installed my WetSeat tailored covers
      Front
      Rear
      Hey Steve Rig looks awesome, Did the wet seat covers cover the back of the seat as the web site kind of shows that they dont and i was hoping to get one that does?
      Rosifumi
      • #48
        Rosifumi
        They cover the back of the front seats. they do not cover the back of the middle seats - so you can access the child seat restraint bar and i guess limit damage when the seats are flat.
        • #49
          Fitted a STEDI 3301 39" light bar before a trip to Coral Bay.
          Not totally happy with the install, as i wanted the bar to be at the same height as the platform so it didn't cast too much light into the cabin.
          Boy it is very bright.
          • #50
            Nice rig Steve, really enjoyed this post as its a similar build to what i want my gxl to look like.
            Keep the posts up
            • #51
              Hi Steve,
              Really enjoyed your post here.
              Im about to build up my vx quite similar to yours. I've just done the rhino rack weeks ago, it was not a so pleasant job, however I loved the result. My next goal would be getting the dual battery work done before xmas, but I'm still not confident about prying those dash trims/plastics. Any chance you have some photos of door sill trims or dash trims or how those clips look like please?
              Any tips will be very appreciated.
              Thanks in advance.
              2018 Prado 150 VX ARB Summit Bullbar ARB Recovery Points Toyota Towbar Rhino Backbone Pioneer Platform Provent Catch Can Dual Battery Blacksys CH-200 and more to go
              • #52
                Generally, i've found the Prado very easy to work on. Keep the simple premise when trying to open facia, etc that if it feels too hard, your not doing it right or not doing things in the right order!
                Fo the main footplate trim unclips - i used a large screwdriver, starting at one end and move to the other. The clips unpopped nicely. The seal around the door frame then peels away and you're good to go.
                For the center console, the shiny upright plastic pieces pull out to reveal bolts for the gearbox tunnel.
                The D-shaped pieces on the side of the dashboard that get sandwiched by the door simply un-pop.
                Use lots of lube (watered down washing up liquid) when running cables through the bulkhead.
                I've tried not to cut things that are not easy to replace - i.e. used the small hatches in the boot for the electronics, so i can replace if i want to remove/change the setup
                I have a photo album on Flickr with possibly more photos
                https://www.flickr.com/photos/stephe...57675841809901
                This/next month i get a set of drawers and a lithium battery setup. Looking forward to installing, not looking forward to the bill!
                Originally posted by vxowner18 View Post
                Hi Steve,
                Thanks in advance.
                • #53
                  I wasn't happy with the light bar being above the platform.
                  In November 2018, STEDI started to produce a lightbar bracket that fitted to the Rhino rack platform.
                  https://www.stedi.com.au/led-light-b...-platform.html
                  This looked perfect - either i could try to install underneath the platform or with an included plate, the lightbar could be installed inline with the front edge.
                  I was able to fit the STEDI 3301 underneath the bar with a small gap underneath.
                  The only thing i need to sort is the antenna mount.
                  • #54
                    So much better.
                    • #55
                      GOLD !! Thanks Steve!!
                      Just got the second battery done under the hood last weekend, Now it's time to put hands on those trims inside the cabin, lol...
                      • #56
                        I installed a set of Drifta drawers
                        To: Drifta drawers with Engel SG30, fridge slide on top, drawer and table.
                        Drawers open
                        Fridge slide for ARB 60l
                        Space for battery
                        Now i know how it fits, it's time to add the charging and switching electronics
                        • #57
                          Nice build mate, who installed these drawers your self ? You had to remove the rear seats too?
                          • #58
                            I installed myself and took out the rear seats - see: https://www.pradopoint.com.au/forum/...616#post743616
                            • #59
                              Those drawers are cool. how big is the drawer fridge?
                              • #60
                                It's an Engel SB30G / 30l drawer fridge.
                                Essentially a 'day fridge' - then the slider above will allow for my 60l ARB to be a freezer on longer trips.
