Shaking - vibrating when idling cold
    Hi to everyone,
    Unfortunately I changed the engine mounts but the vibration is still there…
    I am thinking of checking the valve spacing. Does anybody have the technical manual to see what I have to do exactly? I have seen that for the petrol engine, the adjustment is made by checking the valve adjusting shim size and if it is out of specs, you just change it. I don’t know if it is similar in diesel engines (I have the 3litres 1KD)
    Does anybody have the related document?
      Is there a possibility to have a leak on the vacuum line so I still have the shaking even if I changed the engine mounts?
