2.8TD UniChip
  • #46
    Originally posted by Hally View Post
    Yeah i can confirm too.
    Mine reads boost, egt, dpf, water temp and all the ohter normals
    What are you using Hally?
    • #47
      Scangauge II
      • #48
        Also keep in mind that the Uni itself reduces the tune as engine and IAT increase. I have one fitted to my 1kd and when we tuned it is was based purely on AFR's, The boost, injector duration and rail were all adjusted however the rail was only lifted to keep the fuel supply to the injectors under high duty cycle.
        Coming back on topic an EGT gauge is a must with any modified diesel engine. I had a fair idea of my standard EGT's under the same conditions as when the Uni is switched on.
        I can also confirm than any OBDII reader will not see the modified signal and will only show STD data.
        • #49
          Scangauge II
          Do you know where it takes the reading from eg pre turbo or post turbo? and how accurate do you think it is? It is hard to guage without knowing where it takes it's readings from. Never mind hally just noticed you have the 2.8 its probably different to the 3.0l
          Rdae1981
          • #50
            Originally posted by cuda View Post
            Your mistaken they both do.
            Well there you go! What sort of numbers do you see and what limits do you use for your max?
            I'm also interested where they measure the EGTs at?
            cheers
            Steve
            • #51
              Originally posted by slipperyskakadu View Post
              Will be doing another Dyno run soon as upgrading intercooler and exhaust.
              HI MATE,
              Which intercooler are you considering ?
              Cheers Jono
              • #52
                cheers
                Steve
                Ok on overage the EGT value sits around the 350deg mark but when cruising at 110km in low gear I see 400deg. I have seen 550 - 600 deg when foot flat to the floor pulling 2t up a hill. I think the EGT is measured pre DPF.
                Doug
                • #53
                  Doug
                  That would make sense Doug, I see about 400C at 100kmh on the flat in 5th unloaded (2T van in 4th ups it about 100C). My probe is preturbo, so if you allow 100+C drop over the turbo it all sorta comes out close to what I see on mine. 600C would seem like a sensible, conservative max for yours.
                  t303
                  • #54
                    Dyno runs today at Dynomotive...
                    They fixed the vthrottle response which in turn has fixed the transmission changing issues.... power is great.... never enough for me though lol
                    Graphs Below for those interested! Cheers
                    • #55
                      Was done a 4 wheel dyno. I think a part time 4wd kit is needed. Lose 15kw through driving extra 2 wheels all the time
                      • #56
                        Slippery,
                        which intercooler are you considering ?
                        cheers Jono
                        • #57
                          Originally posted by JIG88 View Post
                          Slippery,
                          cheers Jono
                          I've been looking at the legend x gear
                          Sent from my SM-G935F using Tapatalk
