Hi guys, wondering what are the chances of fitting a 33in tyre under the guards of my MY2012 GXL. From having a quick look it seems my biggest problem would be the front suspension (control?) arm that could rub when turning. Hoping to avoid this with an appropriately offset rim. Any of you guys had any experience with this size tyre?
Max tyre size!!
Being legal or roadworthy, you know so your insurance is not void & your safe, nothing!
In the rules under esc, no vehicle with esc can be modified if it affects operation of the esc.
Grey area. So you then need to go to a vass engineer to see if its affected.
No tyre size change is permitted by roadworthy tester unless they look the other way.
Originally posted by Phs View PostNot being legal aside
Fairly sure a 285/70r17 will work fine on a +10
Call dynamic wheels they will be able to conform which offsets works
Originally posted by Anth120playdo View PostBeing legal or roadworthy, you know so your insurance is not void & your safe, nothing!
Originally posted by 150ricky View PostYeah ok, and no rubbing? I was reading somewhere else on here that they had rubbing with a 32in, but could've been the wrong offset.
By esc do you mean the stability control? Interesting, seeing as nearly all modern cars have it.. I'll have to read into that.
Yes, quite interesting.
esc = electronic stability control.
https://www.vicroads.vic.gov.au/~/me...cles.pdf?la=en
Page8 13.7 it talks about vsb14, a national vehicle standars bulletin.
Second last paragraph
"a vehicle fitted with ESC must not be modified if the operation of the ESC is affected" grey area.
So who defines if esc is affected? A vass engineer, you can look that up too.
I picked up mine running 285 70 17 on 2011 xl . Minor rubbing with brand new tyres just fitted on the rear of the front wheel and by the looks (i've not had it flexing yet ) the rears rubbed when previous owner had Cooper STTs (aggressive tread) on when new. with the BFG AT TA's there seems to be more clearance . Can take some pics later today if you want . Nige2011 GXL diesel , ARB Steel winch bar, Runva 11000 winch , 9" hid , 22" light bar , sliders, , Eaton E-locker rear , 2" OME lift, Poly bags , Piranha dual battery , 285*70*17 BFG AT/TA
Originally posted by Phs View Post^ it's a little bit of a gray area.
at best, 50mm combined as they tested the effects of 50mm raised hight ( by suspension) and it showed no issues with ESC
But combining a tyre and suspension lift combo was not specifically tested nor was just a raised hight by tyres increase
"In December 2016 NSW joined Victoria's lead, allowing 75mm total lift, without engineering certification, but it's likely there will be detail differences between NSW and Victoria. You'd expect that in this stupid federation of eight different legislatures."
The regs in Q are more prescriptive so checknthe fine print. The 75mm is comprised of lift up to 50mm and tyre diamer increase up to 50mm.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by Mavic_Rim View PostWill a BFG KM2 in 265/70-R17 fit without rubbing using a stock rim and no lift?
Thanks,
No, offset is P25 so the tyres will rub up front and to be honest the rim is too narrow.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
