Its not a hard job really to pump it in via the filler. You need to get under there to check the level of the pan when you are finished anyway. You will be amazed how much you loose just with a spill here and a rag there. I was careful to measure everything that came out, and went back in, and I still had to put 400ml in at the end.
I did mine last weekend. I took a photo of the part numbers for the seal, filter and the 2 crush washers for the drain and level checker.
My pan was fairly clean and so were the magnets, I was pretty happy. Though still gave it a good clean and degrease.
