Leak into cargo area, possibly from roof rails.
  • Leak into cargo area, possibly from roof rails.
    I had the 120 parked out during a fair shower, next morning I notice a wet cargo liner and carpet underneath. I opened up jack compartment and jack had condensation on it so left everything open to dry. There is absolutely no evidence of where it could have come from so I an thinking from the roof rails?
    Any suggestions? And if roof rails ha ow do I take off. Haynes guide does not cover.
    Not sure how your rails come off, but the 2 bolts that hold the brackets to the roof are well known to leak. Had to do mine when I found the seatbelt wet after a bit of rain and also carpet it rear seat footwell. Remove bolts, clean area and refit with a bit of neutral cure silicon under the heads of the bolts.
      I've had some issues with the bolts as well - one of the rusted in was a PITA to free up
      Damien
      2003 GXL
      2014 GX
        Defiantly your roof rails. When I put on the roof rack I didn't seal it well enough and had the same problem.
        To remove them you have to remove the clip on covers. Its a delicate operation and you will probably break some of the clips. There was a thread floating around about it about 2 years go. Try and give the search a go.
        [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
