Results 1 to 4 of 4
  1. #1
    Lurker
    Join Date
    Dec 2016
    Location
    North Lakes QLD
    Posts
    21
    Leak into cargo area, possibly from roof rails.
    I had the 120 parked out during a fair shower, next morning I notice a wet cargo liner and carpet underneath. I opened up jack compartment and jack had condensation on it so left everything open to dry. There is absolutely no evidence of where it could have come from so I an thinking from the roof rails?
    Any suggestions? And if roof rails ha ow do I take off. Haynes guide does not cover.
    Member Hogey66's Avatar
    Join Date
    Jan 2016
    Location
    Queensland
    Posts
    238
    Not sure how your rails come off, but the 2 bolts that hold the brackets to the roof are well known to leak. Had to do mine when I found the seatbelt wet after a bit of rain and also carpet it rear seat footwell. Remove bolts, clean area and refit with a bit of neutral cure silicon under the heads of the bolts.
  3. #3
    I've had some issues with the bolts as well - one of the rusted in was a PITA to free up
    Damien
    2003 GXL
    2014 GX
  4. #4
    Senior Member Killswitch's Avatar
    Join Date
    Jan 2015
    Location
    Perth
    Posts
    274
    Defiantly your roof rails. When I put on the roof rack I didn't seal it well enough and had the same problem.
    To remove them you have to remove the clip on covers. Its a delicate operation and you will probably break some of the clips. There was a thread floating around about it about 2 years go. Try and give the search a go.
    [2007 GXL 120 3.0L D4D Auto] Mods: Bilstein Shocks & King 2" Lift Springs - 265/70/17 Cooper AT/3s Tyres - ARB Deluxe bullbar - LED Spotlights & Worklights - Snorkel - BushSkinz bash plates - 2.2m Alloy Overlander Full Rack - 2.5m Wanderer Awning - GME TX3120S UHF & GME AE4703 6.6dBi - Milford Cargo Barrier - JVC indash DVD - Maxtrax - Pulling a heavily modified Jayco Dove Pop Top Camper
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
