Page 4 of 4 FirstFirst ... 234
Results 37 to 38 of 38
Thread: DamoBro's 120
  1. #37
    Lurker DamoBro91's Avatar
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    28
    Another mod ticked off the list today. Solar regulator in place and wired up. Just got to find a panel to fit between my roof rack rails. I wired in the regulator to the opposite side of the narva fuse block. Being a separate circuit, im going to keep that side as an inlet side. I ran wiring from the regulator, to an anderson plug.
    Once the panel goes on the roof, its just plug and play. I also wanted to be able to disconnect from the prados battery, and use the prado as a moving panel for the camper. That eliminates the need to carry my portable panels then.
    Tucked neatly away
  2. #38
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    28
    Hey guys,
    Hope everyone has had a great Christmas.
    I've been a little quiet with the build lately. Here is an update where i am at with it.
    About a month a go this happened:
    Bullbar finally arrived. I was one happy boy.
    Naked Prado
    Fitted 150 recovery points on whilst doing the install
    Went out for my first winch. If anyone is around the Wallsend area and is keen on a 4x4, let me know. I've been living here for about 6 months and started exploring some of the local tracks. Found quite a few good little challenges so far.
    I still haven't install all the bash plates yet. I'm still in the process of tidying a few things. The install of the bullbar was pretty straight forward. Hardest part was getting the measurements right on both sides. Also put the winch in at the same time.
    I am pretty happy with how it is coming along.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
