Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: DamoBro's 120
  1. #13
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    208
    looks good, whats the measurement of your guard to lower rim lip?
  2. #14
    Lurker
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    14
    Quote Originally Posted by ejukated View Post
    Haven't measured yet.
    But i did get my these on. I'm blown away how good it looks.
    I will take a few more tomorrow.
    I'm one happy camper
  3. #15
    Lurker
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    14
    Today my partner went wedding dress shopping with her sister, which meant a day of prado mods for me... yay. I had a few hours, which was ideal for a dual battery install i have been wanting to do for a while now.
    This was stage 1 of the install. Basically just getting the 2nd battery in there, wiring it up, making it look neat and ensure it is all working correctly. For this build i was tossing up whether to have the 2nd battery in the engine bay, or have it in the back. After doing some thinking, and throwing some ideas around, i ended up putting the 2nd battery in the engine bay. I also decided on a basic isolator over a dc - dc set up? Why? Effective, simple set up, and easy to trouble shoot. Plus its a bit nicer on the pocket also. Heres a few pics. Only thing that looks out of place is the small red wire in the background. I don't have any small conduit left. Tomorrows job.
    2nd Battery with the Redarc SBI12
    Inside controls - Haven't hooked the battery parallel switch up yet
    Volt meter
    Stage 2 consists of running 2 anderson plugs to the rear for the fridge, rewiring the factory ciggy socket in the back, and putting in a narva fuse block to keep the wiring tidy. Eventually i would like to also put a solar regulator somewhere near the 2nd battery, and have a 'quick connect' anderson plug for the panel. But at the moment the priority is getting the cabling into the back so i can start running the fridge.
  4. #16
    Lurker
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    14
    I continued to play with the 12 volt side of things today. I bought all the stuff needed to get the plugs in the back sorted, however time was against me. So i got to install the narva fuse block instead. I always like the idea of these but never had one. After the fuse block was done i also tidied some other wiring up.
    Fuse block in place.
    View from the starter battery
    Job completed.
  5. #17
    Lurker
    Join Date
    Mar 2017
    Location
    Newcastle
    Posts
    14
    iI managed to get a couple of small jobs completed. Firstly changed all the globes to leds. Its like day time inside. And secondary, wired and in anderson plug in the back for the fridge, and rewired the factory socket with heavier cable. Pics below
  6. #18
    Hey,
    Prado is coming along nicely.
    I really like the colour of your car, dark green looks smick.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
