Techstream Recommendation
  • Techstream Recommendation
    Hi All, just advice on which ebay techstream to buy.
    OS doesn't phase me as I'll probably use a netbook on XP.
    However if there's any advantages on using Latest Firmware V2.0.4,K-Line+CAN,Support 64bit & 32bit I'll bite.
    Some post's I've browsed through were older variants or ebay links expired.
    Thanks in advance
    Not really that tech savy to post the link. I got the one for $56.90 from auto.lines off of eBay. Got it in yesterday's mail and put it on a laptop with a cd drive I bought of gumtree and worked straight up.
      i bought this one - http://www.ebay.com.au/itm/191714810...%3AMEBIDX%3AIT
      but i'm not tech savvy in any way and couldnt get it it going without some help from a computer place. the guy found details on a workaround here - http://www.toyota-4runner.org/genera...-8-64-bit.html
      sorry i cant help any more , the whole thing was above my capabilities , well above
        Is the techstream for reading injector values and clearing fault codes?
        What else can it do?
        Is it the simplist way?
          not sure , ive done some Youtubing and found it does change some settings on some models
            Techstream can also input new injector codes. It will also run diagnostic tests on numerous operating systems including fuel leakage tests. Scanguage can also clear codes but can't input values or read feedback and other critical operating parameters.
              I did get in touch with Scangauge a while ago requesting the codes to enable reading of injector values on the fly, much like torque converter temps etc and they said it was theoretically possible, but after a few attempts they gave up.
              Is anyone computer savvy enough to decode the serial data being sent and received over the USB?
              2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
              2008 Jayco Dove Outback - "Davo"
                Is anyone computer savvy enough to decode the serial data being sent and received over the USB?[/QUOTE]
                What are you trying to achieve, and what end is serial and what end is USB? What software are you using? Lot of things can be wrong in this connection type. So need lot more information to troubleshoot this connection issue.
                D4D. How long will it last?
                  ended up buying one from ebay id: Auto.Lines
                  $56
                  purchased with techstream, 10.10.018
                  CD was damaged in transit. seller provided me with dropbox link.
                  Working on XP, W7-64bit and WinX-64Bit
                    $56
                    Do you actually have it working on Win10 ?
                    I can install simple stuff but all the sites I have read have said that Win10 requires registry fiddling and I am not game to go there.
                    Can you please explain the steps you took to install to Win 10
                    thanks
                      thanks
                      Yes.
                      No fiddly reg. edits or anything, the xhorse update tool doesn't work with winX (.exe file) but it provides the driver within Techstream to use the ports and cable provided..
                      The USB cable with FTDI chipset almost installs itself and illuminates. I knew there was no issue with the cable.
                      I'll lookup the instructions that came with it and reword it later today.
                        Is it the one?
                        http://www.autolines.com.au/index.ph...rch=techstream
                        2013 ZR in Crystal Pearl With Bits From ARB Catalogue.
                          It was the seller Auto.Lines on eBay. Yes.. same as that site. However might be safer buying through eBay.
