Ironman foamcell pros
  • Originally posted by oneday View Post
    Hi Mark,
    Could you please put me in the group buy list? For FJ Cruiser, front and rear (softer version) kit, 50mm lift, heavy front end and light rear (0-150kg).
    Will
    Hey Will,
    Have added you to the big list!
    • Originally posted by Whitey View Post
      Hey Will,
      Thank you Mark, can hardly wait.
      A newbie question. FJ's rear OEM swaybar limit is somewhere between 610-615mm. Other than extending swaybar links (Easily DIY-able?), can shock's open length be reduced from 618mm to 610mm?
        Hey again,
        No the shock open length can't be reduced.
        It's pretty straight forward to either space your oem swaybar links down a little, or to simply buy longer links and install them. I'll offer longer links on the group buy!
        • Awesome.
          • Thanks Mark. That solves that. My choice will be whatever works best with your shocks. Sounds like the Dobinsons 327 then for the back and whatever you recommend for the heavy front. Can't wait.
            • Originally posted by 404pug View Post
              Hey Neil,
              Yep the Dobbos 327 coil is a pretty good off the shelf choice for the rear. If you're struggling for lift with a heavy constant load rear like built in draws, rear bar etc., you can always go up to the 420mm 627 or the 430mm 487 coil which is what I run.
              If you're heavy up front, I'd try the 725lb/in 150 spec Dobinsons coils, they'll work well with the valving, and you can always get a shorter free height 380mm coil and wind it up on the preload. The height adjustability on the front simplifies everything!
              I think you should also not go over 725lb/in on the front, as the front:rear suspension frequency ratio begins to look crappy!
              Some will prefer King coils obviously, but everyone should keep in mind there's a big gap in coil rate, from 660 to 800lb/in for the front Kings.
              I am running the Ironman 669lb/in TOYO55B front coil with my steel ARB bar, and my front end has never ridden so nicely!
              There's a lot of coil choices, so I'll also give some coil choice selection guidelines in the buy that will be based on weights. Hopefully this will simplify things! I hope!!
              • I suspect that mine is like a lot on here. Steel bull bar, 2nd . battery, a couple of driving lights, no winch [ nor is one likely], just maybe a bash plate. So I guess that that 669 lb coil that you have will suit a lot of us in the buy and keep things as simple as possible. You are really educating us Mark. Good stuff.
                • Hi Mark,
                  I'm following this thread and I am very interested to be involved when you're ready,
                  Regards
                  Aaron
                  • Originally posted by Azzman77 View Post
                    Hi Mark,
                    Regards
                    Aaron
                    Hey Aaron,
                    I've added you to the list!
                    • Getting pretty keen to get some new legs under the rig, 150,000km still original springs and shocks. Lets just say the ride isn't that smooth
                      • Originally posted by luke666 View Post
                        Hey,
                        That's a lot of km's on the OEM suspension!
                        Get ready for a serious transformation!
                        • Yeh bought the rig off an older couple that just used it for towing a TVAN camper around so it needs a few little upgrades here and there but especially the suspension so on the edge of my seat waiting for your kit to get up and going.... don't want to sound pushing as you can't rush a custom setup like this but what sort of time do you think Whitey you'll start rolling them out ???????
                          Regards Luke
                            Regards Luke
                            Hey Luke,
                            Monday should be the big day!
                            Still testing my softer rear valving and some different front coils this weekend, but they will be straightforward tests.
                            All the logistics are in place and I'm hoping no stock delays!
                            Fingers crossed the Group Buy thread will be up on Monday.
                            • Good to hear it is all progressing nicely. Looking forward to Monday a little more now. Sadly I'll still be at work all day
                              • Hey, a good birthday present for me [ and my car]
