Best valving for corrugations
  • Best valving for corrugations
    Hey all,
    I thought we could start an interesting thread about what the best type of suspension setup is for driving the Prado on corrugations. Hopefully many of you can chime in with your own experience from your preferred setups.
    There are a few theories around on what is best, and many factors involved, including tire pressures, coil rates, and perhaps most importantly valving. Not surprisingly, there are not so many valving numbers for the “best” setups, so hopefully we can get some real dyno data in this thread to support these cases.
    The tire itself acts like a coil spring, and has its own pressure dependent tire load-deflection rate. As is usually the case with suspension, there are always two sides to the argument. While you will hear many say to run tire pressures to 25-30psi for corrugations, there is also another not so well known theory that running high tire pressures is better, up to 50psi (this theory has its origins in F1 racing, and means the suspension must be softer to absorb the bumps). For each of these cases the suspension will need to be set up differently, softly for the high pressure tire case, harder for the softer pressure tire case.
    There is also again the subjectivity of what one person thinks is a great setup for corrugations will not be enjoyed by someone else. Many will say to have the suspension set up softly regardless and believe the ride comfort is excellent, all the while with the sprung mass oscillating up and down.
    There are also many anecdotes, such as “keep the compression hard, and the rebound soft” apparently so the soft rebound allows the suspension to “get down more easily” into the deeper parts of the corrugations, with the harder compression stopping the higher bumps lifting the vehicle too high. These types of anecdotes are usually quoted for adjustable shocks with no knowledge of the valving or the range of adjustment.
    Speed is also a big factor, and one theory is that the faster you go the more easily you’ll skip or glide over the corrugations. How easily you do this can depend strongly on your suspension travel and the depth and length of the corrugations.
    There are also important kinematic factors to consider, the rebound:compression ratio in the rear of the Prado is crucial to the stability of the Prado, the classic “pogo stick” dynamics are notorious. Other factors are the front:rear coil rate ratio, which will strongly affect the vehicle pitch via natural frequencies, and the ratio of front:rear ride rates.
    Regarding the important rebound:compression ratio for the rear of the Prado, I believe that solid axle spec valving works the best, and valving in the 3000N:500N up to 4000N:1000N is the most common solid axle valving you will see on a wide variety of solid axle vehicles. Typical coil rates are in the 230-320lb/in range for this valving.
    It is interesting for example to see the recommended settings for ARB BP-51 rear shocks yielding 4250N:920N at 0.52m/s. This is very close to the commonly used Bilstein B46-1478LT valving of 4000N:900N. It is also very close to the 3925N:910N I’m using in my custom Ironman Pros.
    So it’s no real surprise to see these kinds of solid-axle valving figures for the rear for both non-adjustable and adjustable shocks. However it’s not the end of the story for the rear, and many who have adjustable shocks like the BP51’s will tweak the compression and rebound settings around dependent on their tire pressures, coil rates, and the weight of their vehicle and driving style.
    In the front we are strongly limited by the IFS motion ratio in valving terms, so at the strut position it will be quite common to see struts with 2500N:1500N up to 3600N:2200N. Some struts will use even higher rebound Forces up to 5000N. Coil rates can typically vary from 600-800lb/in. In handling terms, it is better to have the front softer than the rear, something which is in any case forced upon us by the scaling nature of the IFS motion ratio. Keeping front:rear coil rates around the 700:300 ratio ensures the rear suspension frequency will be higher by around 10%, thereby minimising wheelbase length induced pitch for long spacing corrugations, while also keeping the front ride rate around 25% softer than the rear. Running a low front strut compression around 1500N leaves the IFS open to hard bump outs on taller corrugations, so keeping the compression around 2000N is preferable.
    I have personally driven the 712/713 Bilstein setup on Ridepro coils with a heavy Prado over GVM on 50psi tires as a test case along the Great Central Road. The 712/713 are just copies of the OEM valving, and are considered as soft suspension on the Prado. This high tire pressure/soft suspension setup worked well, and handled nicely. I’ve also driven the complete opposite with soft tire pressure/hard suspension setup, with more like the valving discussed above, and the handling feels similar to me. In both cases I was driving at 90-100km/h.
    I’d like to hear from anyone who has some feedback about their setup on corrugations, regardless of how you do it. It would be great if you could list your tire pressures, coil type/rates, strut/shock used, vehicle weight and vehicle speed, and the corrugated roads you’ve driven on. It doesn’t matter if you don’t know your coil rates and strut/shock valving, just as long as you know the manufacturer, as I can find the coil rates and valving.
    Hopefully this thread will become a good tool for great suspension setups to eat up those corrugations!
    Hey Mark, as I have posted elsewhere my [now sold] 120 had OME with medium springs all round and the sports shocks. This combo. worked well on corrugations when loaded [don't know about empty]. Rears lasted 60,000km before one started leaking and went hard. The fronts had 90,000 on them when I sold it. However the ride empty with 4-5 psi in the polyairs was crap and this was coming from the rear. The front only had a sovereign bar on it and a few issues arose here especially on the scolloped uphill parts of dunes.The problem was with the light weight the shocks topped out unless you nursed them [which I did]. On most dirt roads in the centre I run 28psi and sit on 80-90kph. On the killer corrugations on the CSR I was running 20psi and found that about 60 kph worked. The front shocks never faded in these conditions but the rears did fade a bit but always came back with a few minute's rest.
    Perhaps one other factor to consider is the tyre type : BFG ATs were fine when new but I have found over 4 sets in 2 cars that they become very hard riding as they wear at approx. 40000km.
    As an aside my 150 is still on the standard suspension and it is poor by comparison with the above setup on corrugations. Consequently I am watching the suspension stuff you are posting very carefully! Cheers.
      Hey pug,
      Great post! I'll try and find some OME rears and get them up on the dyno so we get an idea of the valving. What ride heights did you have on the front when you were getting the top outs?
      What tire pressures did you run on the standard 150 suspension? When you say it was "poor", was it pitching around a bit?
        I too am looking at this thread with interest, as I am after a suspension upgrade from OEM in the following months!
        I did find this website and ebook handy when planning a trip like the Great Central Rd. Wrtitten by a young family living in remote NT/WA border on the GCR. Interestingly he discusses corrugations and has a 150 series. A bit more about pressures and speeds, but still worth a read.
        http://www.yourtripright.com/driving...ted-roads.html
        http://www.yourtripright.com/suspens...-grounded.html
        Good tips for all touring, camping etc
        -Safari snorkel
          Mark, the front on the 120 was 810 when first done but quickly settled to 795 mm where it basically stayed for the next 90,000 until I sold it. The back went to 813/810 and 90,000 km later it was at 805 mm with the airbags at 4-5 psi. I just found the specs: 884 front springs and 9000 sports shocks; 895 rear springs and 6004 sports shocks.
          I was running the 150 at 28psi on corrugations but it was only short sections not long ones like the outback [tyres are Cooper AT3- softer ride than the BFGs and much better at self cleaning mud from treads.] Neil
          PS "poor" because it pitched and rolled and nose dived like a barge . The standard suspension is too soft for anything other than no load on a tar road in an empty car driven sedately [ like most of them probably are!] ie ok for a city car but less than ideal for a country tourer.
          404pug
            Hey Ghandi,
            I have read these threads many moons ago, it is a nice piece of work. Many manufacturers use this technique and will do off-road testing with an accelerometer on the sprung mass. The point of course is to minimise the up/down motion of the sprung mass to give maximum passenger comfort. Meanwhile the unsprung mass will be doing all the work underneath, with the suspension cycling beautifully through the undulating terrain. That is the theory, in practice it is difficult to reach.
            The other point of interest not present in these threads is the valving and the coil rates. This leaves the threads on a rather empty note. He has custom valved Konis, but what is the valving?
            I have dealt with the Koni distributor here in Australia in an attempt to get valving figures for Koni setups in Prados, and they are paranoid about releasing any information. So I just avoid them and dyno by myself, no big deal.
            The off the shelf 90 series RAID for the rear of a Prado has similar valving to a 713 Bilstein, and will turn a loaded up Prado into a pogo stick, so it is no wonder they are getting cutom valving done for the 150 in those threads!
