Rear 240v power board
  • Rear 240v power board
    Hi All,
    I am sure many of you have come across this issues at some stage. I have a 4 outlet powerbaord plugged into the 240v outlet. The powerboard has flat plug where the wire comes out to the right when it is plugged in. That makes the wire head out towards the rear tail gate and has got stuck in the door few times. I have looked and have not (yet) found a powerboard where the wire is heading to the left as it leaves the plug. Has anyone found a solution to this issues?
    Thanks.
    D4D. How long will it last?
    Bunnings have an extension cord with swivel plug
    https://www.bunnings.com.au/arlec-2m...-lead_p4334338
    This one exits to the left
    https://www.bunnings.com.au/arlec-6-...board_p4420151
      Thanks amts, for some reason all the searches and the images showed the wire exiting to the right.
      Problem solved.
      Cheers.
