Hey Spring,
Not enough rebound in the 712 to control a 725lb/in C59-350, and the open length of the 712 is too short. Better front strut to use is the D563, however, at 575mm open, you'll need to look at after market arms unless you get it shortened slightly to 570mm.
The rear C59-325 is too soft and mismatched for the 24-217897. Use a 270lb/in C59-327 instead with the 24-217897.
The quote seems high, give John at Zordos Suspension in Brisbane a call, he'll sort you out with a good Billies setup!
