Injector diagnostics 1kd-ftv
  • Injector diagnostics 1kd-ftv
    Some people ask, what's a diagnostic?
    Diagnostics is a process of identifying or determining the cause of symptom.
    We methodically practice techniques of diagnosis, it's an art, a science.
    An in-depth evaluation with a relatively narrow scope of analysis, aimed at identification of a specific condition, problem or abnormality.
    In regards to 1kd injector diagnostics, there are many parameters to read, which vary depending on a number of things. It takes a lot of time & experience to learn what is normal or not & accurately diagnose what is causing your symptom.
    So DIY diagnostics on injectors is a good idea, but now and then you should get an expert opinion.
    good advice , thanks.
    will the same principles apply to the 1GD despite they being a different injector type?
      I don't know much about the 1gd.
      I always said hold off on buying one, from what I have heard, some are glad they did, & there are some regrets, but I'm sure many are very happy so far. Lets see in time, we will learn what the faults are if any. Too early to say.
      In modern vehicles, diagnostics is the key.
