Toyota Prado 120 Offset
  • Toyota Prado 120 Offset
    Hello,
    I would like to place the wheels more outside than stock meaning a little before the limit of the wheel arch. Does anyone knows the offset of the rim to do it?
    Any pictures. If I'm not mistaken the stock offset it's +30 mm.
    Thanks a lot.
    Closer you go towards 0 offset the further the wheel will go out.
    Stock 120 wheels are +30mm as you say i believe to be true.
    150 wheels are from memory +15 or +20 i forget now. Either way they move the wheel face out 15-10mm as you require.
      150 wheels are P25 (except the early narrow GX rims). FJ Cruiser are P15.
      Quite a few people have fitted FJ rims but please check your local Transport regulations because some states limit any increase in track to 25mm.
        Hi mjrandom.... heaps to read in this thread. I have been reading through and there is some good info in here.
        http://www.pradopoint.com.au/showthr...ffset-Database
