Dumb question, but what does it cost per min to call a satphone ?
Satphone costs ?
Satphone costs ?
[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]Tags: None
Depends
Are you calling TO a SatPhone, or from a SatPhone?
Calling from a SatPhone dpends on if you own it (or borrow it) or buy it under a plan. Call costs are here:
https://www.telstra.com.au/coverage-...bile-satellite
There are other options. If you have a SatPhone, you can put a basic simcard into it (with international roaming switched on) and pay per minute. It gets expensive if you run long calls, but worth it for emergency calls.2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
