Results 1 to 8 of 8
  1. #1
    Lurker
    Join Date
    Jun 2014
    Location
    north curl curl
    Posts
    10
    Diesel service on northern beaches in sydney
    Just wonering if anyone knows a good service centre for my 2013 vx Prado.
    Now its out of warranty wont be going back to local toyota dealer as they are hopeless.
    Regards,Chris
  2. #2
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    222
    I take mine to Chatswood Toyota when needed, driving right past the local dealer on the beaches
  3. #3
    Join Date
    Mar 2014
    Location
    Earth
    Posts
    140
    Chris, if you don't mind can you say (PM is best) who that local dealer is and what the issue/s has/have been, as I also have my vehicle serviced around that area and coming up to end of capped service schedule.Thanks
    D4D. How long will it last?
  4. #4
    Lurker
    Join Date
    Jun 2014
    Location
    north curl curl
    Posts
    10
    I have been away not to sure how to do a pm.
    Chris
  5. #5
    Join Date
    Apr 2010
    Location
    Sydney, NSW
    Posts
    255
    I agree with the preference for Chatswood Toyota over the local mob. Mine is now out of warranty and lease, so I've taken it to Mark's Auto Care at Mona Vale recently for the 120K service and was happy with th brief discussion over the phone before booking, final price and quality of the work done.
    2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
    2008 Jayco Dove Outback - "Davo"
  6. #6
    Lurker
    Join Date
    Jun 2014
    Location
    north curl curl
    Posts
    10
    Hi
    Thanks for the information about Marks at Mona Vale,I am a bit reluctant to use toyota dealers after problems after any service I have had especially buckles.
    After the final service at warranty end recently my prado is now using more fuel than before and my exhaust system is now making metalic cooling pinging noises like a new car can do when you turn the engine off.
    Chris
  7. #7
    Join Date
    Feb 2006
    Location
    Sydney, Australia
    Posts
    222
    Perhaps check your o2 sensors? If old or faulty could be causing increased fuel consumption and side effect is hotter exhaust gasses.
    After having my clutch done at Buckles I found 2 loose driveshaft bolts and the transfer selector wasn't bolted down fully causing water to get in and start corroding the internal shift rods. Cant think how else those things could be loose considering they aren't normally touched and they are specifically removed for a clutch job.
  8. #8
    Lurker
    Join Date
    Jun 2014
    Location
    north curl curl
    Posts
    10
    Thanks for the information I will look into it.
    Chris
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
