Bad Engine noise/Oil light on. HELP!!!
  • #61
    Originally posted by nudgebar View Post
    I cant tell the difference .
    have you found the turbo and check engine faults?
    I cant tell the difference driving it. Happy with the end result.
    The Engine fault was the fuel rail pressure switch. I had to change it out and fixed that fault. Engine check light has come back on again due to EGR fault. Im thinking that is a result of the exhaust leak around the turbo. I do have a 7mm EGR Block but have had that for over 12 months with no fault.
    • #62
      TurboD4D,
      How is the old Prado going?
      [COLOR=#0000ff][/COLOR]120 Series Prado 2008 Dec - Diesel Auto - One owner with FULL Toyota service history - [U]D4D FAILED at 128,000klms[/U] Central Australia after Simpson Desert Crossing - Counter balance shaft failure - Our Toyota servicing dealer of 7 years didn't care, Toyota Australia didn't care - Installed brand new long engine,.... Ouch!. $$$$$$$$$$
      [B][URL="http://www.pradopoint.com.au/showthread.php?39021-Got-the-D4D-blues-Oh-what-a-feeling-("][COLOR=#0000ff]Got the D4D blues, Oh what a feeling ;-([/COLOR][/URL] [COLOR=#ff0000][B]"Toymotor" [/B][/COLOR][/B]
      • #63
        Originally posted by TurboD4D View Post
        So rang an Engine rebuilder in Perth today who has done "2 x 1KDFTV Balance Shaft Deletes last week" to find out how he blocks of the oil flow to the rear bearing to maintain oil pressure and he said all they do is When they put new bearings in they spin them so the oil hole is blocked.
        I mentioned that I was told the bearings cant be purchased on there own. He laughed and told me about the 2 motors he did last week and said he buys the bearings form "Engine Australia" (http://www.engineaustralia.com.au/) Gave them a ring and yep $36 for the set.
        He also said that the balance shaft delete can not be done on the Auto but defiantly can be done on the Manual. (Im in Luck) Apart from blocking the oil hole at the rear bearing nothing else needs to be done.
        Have just found an oil pump today so will start putting it back together Thursday Hopefully drive to work Monday.
        How the balance shaft delete worked out ???
        • #64
          OP hasnt logged in for a couple years. suspect an answer might be slow in coming.
          • #65
            What's the thing with the
            The engines are the same !!!
