Accessory and radio stay on
  • Accessory and radio stay on
    Help
    I have a 05 120 Grande I plugged in a faulty compressor to the rear power outlet which blew the fuse immediately, after I replaced the fuse and deposited the compressor in the bin I found the ACC sockets, radio, and gear position indicator were not turning off with the ignition.
    after a bit of reading and investigation I came to the assumption that I have damaged the ACC relay (I have a workshop manual and have traced the circuit back to this), however, does anybody know where the ACC relay is in the 120 series. cant find any referance to it in the relay cluster drawings and i have removed just about every relay i could find.
    From the documentation I have, there is an ACC CUT relay. Haven't confirmed this on the vehicle though. This cuts power to the accessories when the engine is starting.
      yep I have the workshop manual that says the same but doesn't tell me where it is
