Results 1 to 4 of 4
  1. #1
    Noise under drivers floor panel offrroad
    Just got a 2011 GXL prado manual transmission. When offroad and the drivers front wheel slips, there is a grinding noise under the drivers seat and the slip light/traction control flashes. Am in 4lo when this occurs. Only seems to happen with the drivers side wheel. Can't hear noise on the other side.... Any ideas?
  2. #2
    Administrator Piggy's Avatar
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,540
    Blog Entries
    4
    Traction control applying brake to whichever wheel.
    The traction control solenoid/valve setup is located in front of drivers feet.
    I suspect that's what your hearing.
  3. #3
    Yeah I figured it would be related, but didn't think it should be so noisy? I first thought we had bottomed out on the hill we were going up, it's that loud...
  4. #4
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,540
    Blog Entries
    4
    It's quite snappy. Louder on traction than it is on ABS.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
