WA: 2009 GXL White, D4D, Auto, 8 seater, 140,000 k's (Bankrupt) $35,000
  • WA: 2009 GXL White, D4D, Auto, 8 seater, 140,000 k's (Bankrupt) $35,000
    Howdy all,
    The time has come whereby a larger family members means we need extra tow capacity to pull a family caravan, so I have ordered a new 200 series.
    This means Bankrupt is up for sale and I really hope it goes to someone on here that will appreciate it for what it is.
    I've owned the car since new and done all the mods so I can answer any question you have so feel free to ask.
    Failing that, the best way to learn about the car is to look at the build thread on this forum, it's pretty much a 'pants down' look at what this car has.
    http://www.pradopoint.com.au/showthr...KRUPT-s-09-D4D
    In addition to what is in the thread I have recently replaced all injectors, injector lines, rotors, brake pads (inc hand brake) and timing belt with new Toyota parts. Its also just been serviced with all fluids changed and I mean everything. Those that are in the know will realise this is ~$6k not including labour. Its also had new tyres.
    For those that can't be arsed reading the build thread here is a quick snapshot:
    - 2009 White, Auto, GXL, rear air-con, rear parking sensors (First registered May 2009)
    - ARB colour coded bull bar c/w recovery points
    - Lightforce 240 Blitz spotties
    - 2" lift made up of Bilstein shocks and Lovells coils
    - Polyair air bags fitted to rear coils
    - Brown Davis under body armour, both engine and trans
    - Pradopoint rock slider side steps
    - Tripple batteries c/w charging system
    - ARB front and rear diff locks c/w ARB onboard air compressor
    - Beaudesert s/steel exhaust including dump pipe
    - Snorkel
    - GME TX3420 UHF + aerial
    - Rear power plug for fridge
    - Toyota seat covers front and middle row
    - Toyota tow bar
    - Toyota factory privacy glass
    - Window tinting all round (20 grade)
    - Eclipse touch screen DVD head unit c/w satellite navigation and reversing camera (Eclipse produce the factory units, but this was the top of the range item)
    - Toyota carpet mats throughout and also Toyota rubber mats including rear cargo mat for muddy weekends away
    - BF Goodrich All Terrains 275/65/17 x 5
    - Rear Pradopoint work table mounted to rear door
    - Rear cargo area also has floor replaced to accept a Waeco 80ltr fridge slide and cargo tie downs.
    There is also a Tracklander alloy roof rack and ladder c/w awning, wind deflector and work lights that can go with the car for a few extra $$'s if needed but I'm just as happy to keep them for the 200 series as I will be fitting the same system to it as well.
    I'm sure I've forgotten things so best to have a look.
    Thanks for reading this add.
    Ps: Despite the heading saying 8 seater it could actually be a 7 (Give me a break, I'll have to look tomorrow as I pulled the rear seats out in its first week and they've be wrapped up ever since
    Jase
    0412 755 498
    Bankrupt
    2009 GXL D4D White Auto - ARB Duluxe Bar - Lightforce 240 Blitz spots - Icom IC440 CB - Bilstein shocks, Lovells 1.5" lift H/Duty coils - Polyairs - Tracklander Alloy roof cage and ladder - Maxtrax - rear work lights - PP Rear-door-table - Underfloor water tank - 275/65/17 BFG AT's - Ranox dual battery system - Rear door spacer - Safari snorkel - Steel sliders - ARB front and rear air lockers - ARB CKMTA12 onboard air compressor...
    SOLD - admin please move to sold thread. Cheerc
