2012 Kakadu front camera wiring help
  • 2012 Kakadu front camera wiring help
    I have a question for anyone who owns a 2012 Kakadu and has a front camera.
    I have a 2012 Prado Altitude and behind the Toyota badge at the front of the car there is a connection I think might be for the front camera.
    https://www.dropbox.com/s/p1cevzsrll...20pm.jpeg?dl=0
    I'm hoping someone can confirm for me if the above plug in my photo is for the front camera
    Thank you
    Hi Starbucks
    Hope this helps I extended my cameras wires on our Kakadu to relocate it onto the ARB bar and took some photos of the plugs after I extended them.
    If you pull the sleving back on you're exsisting plug there should be four wires a white, brown, red and black.
    Good Luck
    Jacques
    2012 Pearl White KDJ150R Prado Kakadu
    ARB Deluxe Bullbar & UVP Plates
      Thanks Jacquesleroux,
      I will investigate this weekend and report back.
      I have a spare eclipse bec108 camera that I purchased a few years ago sitting in the garage and was thinking I'll give it a go and use it.
        I dont think so that canera will work. Toyota use 6volt camers not 12 volts. If your planning to install fromt camera better use aftermarket headunit as well. Cheers
          What products did you use? My camera only gets a view of the back of the driving lights and a very narrow gap between them, I really need to move it elsewhere on my TJM bullbar.
            Its easy you need to extend 4 wires which connects the camera thats all. . N install where ever you want. Took me 3-4 hours making bracket n rest.
              I used the same camera on my old prado 120 grande as a reversing camera hooked up to the factory display
                We are talking about 150 not 120. 150 kakadu use 6 volt cameras not 12v volt. May be your camera take 6v -12v. N how will you see the picture on factory camera. Factory camera wiring is different from aftermarket camera. N i am Pretty sure factory headunit doesnt have video output for front camera. N do that you need module to work.
                  Fujitsu-Ten Eclipse BEC108 Camera Specs.
                  • Picture element: 1/4" color CCD
                  • No. of CCD pixels: Approx. 270,000
                  • Horizontal resolution: 300 TV (center) or more
                  • Camera: Focal distance: f=1.3 mm
                    F value: 1:3.0
                    Angle of view (horizontal/vertical) : 135°/105°
                  • TV format: NTSC standard
                  • Standard image output level: 1.0Vp-p (75.0.)
                  • Minimum object illumination: 1.41ux (25IRE)
                  • White balance method: Automatic
                  • Automatic sensitivity adjustment range: 1:1600 or more
                  • Power voltage : 5.7 - 8.4 V DC
                  • Current consumption: 130 mA Max. (at 6 ± 0.3 V DC)
                  i think i'll be ok with the voltage. i may however have to setup a switch or something to display the camera on the screen. will update when i have tinkered a bit
                    OK, but what connectors did you use? Did you make the bracket yourself and do you have a template?
                      Just cut the factory wiring and extend all 4 with same gauge wires about 250mm in length n bracket was made by me. That was the most timing process. Around 3 hours.
                        I went to Jaycar and bought 4 pieces of 300mm wire to match the existing loom colours and 2 sets of Deutch plugs. I added Deutch plugs too the existing loom too keep everything water proof and made a 250mm extension cord to extend the camera into a bracket I manufactured to relocate the camera into the space above the winch cutout on my ARB bar and if I ever need to go back to original I can just unplug the extension piece.
                        jacquesleroux
                          Hey Guys, I have a VX so I have the same wiring as the Kakadu. Behind the grill there are a few spare connectors. One is for the front camera and the other is for radar cruise. I grabbed 12v from the radar cruise as the VX doesn't come with option and then spliced into the other connector for the Video Positive and Video Negative. It then travels through the factory harness down to a junction block at the drivers side. I then spliced an RCA cable into the two wires and used that as an input for my head unit.
                            Hi Rackxp,
                            You wouldn't happen to know what each color wire is for, the camera plug at the front had Black, White, Red and Brown.
                            do you have a photo of this junction block?
                              Hi Jacquesleroux,
                              I'd like to copy what you did as I have a VX as well. The Deutch Plugs ( extension and small one) and Camera can be bought at Jaycar? And how is it look at the screen ? Do you have to install a switch to select which monitor you want at the screen/ or how screen looks like if you want to see front camera ? More pictures and info please .
                              Ceasar
