Rookie mistake - forgot to mark polarity
  • Rookie mistake - forgot to mark polarity
    So, I thought I'd be clever and fit an Andersen plug to a Thumper air compressor as it come with alligator clips. I made a mental note to mark the polarity on the cable as both leads are black, but I got carried away and that mental note vanished! :-(
    I've done a bit of Googling, and I'm not the first one to make the mistake in doing this exact same exercise (other rookie was a Paj owner), however he took the gamble and it paid off. I'm not so gutsy.
    Can anyone shed some light on what safe options I have?
    - Not overly keen on opening up the compressor
    - Don't want to buy another one
    - Don't want it to blow up in my face, or damage the car
    TIA!
    2003 GXL V6
    Safari snorkel
    +ve wire usually has:
    - writing on it or is striped.
    - is switched.
    - is fused.
    The last 2 will require opening up the covers, etc.
      Thanks. I did find a thread where someone had opened up the compressor and I'm guessing the +ve goes directly to the fuse.
      2003 GXL V6
      Safari snorkel
        If you have a multimeter or know someone with one check which cable is earthed to the compressor via a continuity test.
          I pulled it apart and traced the cable from the switch and fuse. Tested it out and all good.
          Thanks again!
          2003 GXL V6
          Safari snorkel
