KDSS lean any recommendations in vic ?
  • #31
    Any idea what they done to solve it ?
    • #32
      Hey seeker,
      As for my case I don't think it was initially set up correctly from the front spring pre load to the rear air bag sensor spacers ect.
      From what I heard statewide have a shaker deck that they can open the KDSS valves slightly and just shake it and shake it. Until it still level and any air is expelled
      Airbag man were great with helping sort it out the rear and the front pre load was adjusted photos attached as it is now
      It's is great, can't speak more highly about the BP51s on road there smooth yet add a lot of stability and off-road they soak up all the bumps
      • #33
        I've not had any dramas with the lean since the Dobinsons gear in. I do find if I have parked it on uneven ground and then drive off it will lean but that's how the hydraulic sway bars work. I find a few left to right formula 1 style and it's all good again.
        I"ll find some level ground and post some photo's of my measurements.
        Sent from my SM-G935F using Tapatalk
        • #34
          Looking at the thread count they have preloaded the righthand side more effectively making the spring longer on that corner.
          That does the same as fitting a longer spring (Or shorter on the other side.)
          Its taken a lot of difference though. I would leave it alone if it is within 10mm. You will be chasing rainbows from now on.
