KDSS lean any recommendations in vic ?
  • KDSS lean any recommendations in vic ?
    Hi,
    Just had 2" lift fitted today and no good, cars sits 50mm to drivers side. ( 50mm on the back and 45mm on the front )
    I had gone through the motions prior to Install and was reassured they knew how to bleed the KDSS
    they went about it the same as a 200 series on level ground loosened screws and re tightened.
    Well that's if they bleed it at all
    Anyway just need to sort it out Can anyone recommend someone in Vic to level it out ?
    What did you install?
      Airbag man 2" Kakadu lift
      With
      ARB BP51
        Are both adjustment rings on each strut set at the same height?
          The fronts come specific to suit KDSS part numbers are different For drivers and passanger side
          Not sure now they set them up, but even the back measures 50mm L to R
          Phs
            Please post photos of the struts both sides.
              Hi amts,
              Just through the wheel arch with tyre on ?
              Im not going to drive it I'll borrow a vehicle for work and wait to hear back from the installer
              2" lift with a 2" lean is definetly not acceptable.
              Even better I'd rather just take it to some one that knows how to fix it and just get on with it
                Turn the steering full lock and take a photo showing the entire length of the strut and a closer one showing entire length of the coil.
                Repeat both sides.
                Is the driver's side lower?
                  Yes, drivers side is now 50mm lower front and back
                  I'll take a few shots
                    drivers strut
                    drivers spring
                    passenger strut
                    passenger spring
                      They both appear identical. Any different markings on the coils?
                      What is the number of exposed threads above the adjustment collar?
                        Good work helping out amts.
                        If I may interrupt?
                        Can I ask is it the passenger side high?
                        Have the neutralised the kdss? Like really?
                        Apparently there may be a service bulletin on it, maybe go to a toyo dealer & ask.
                        I thought we did ok with a few, but they even change later.
                        I give up in anything with kdss, hate it.
                        I'm pretty sure the sway bar is your issue. Very sure.
                        Too late now, but for others in the future, if you need an offroader, stick to coils & standard sway bar.
                          18" wheels
                          Passanger side front 825mm
                          Passenger side rear 840mm
                          Drivers side front down 45mm
                          Drivers side rear down 55mm
                          ####, no idea what they did with the bleeding ect.
                          It has a factory swaybar and had a factory Airbag setup
                          Amts, I did my homework prior and did confirm the front left is different for KDSS models and I supplied a part no. they agreed
                          Looked at top Sturt adjustment looks like the passanger side has 1/2 a turn more spring load but could also just be the thread orientation
                          I purchased a few spare Kakadu rims from a gentleman a while back that mentioned his KDSS lean His installers attempted 3 times to fix it with no luck
                          He did get it fixed somewhere els.
                          Lucky I remembered the company and managed to get onto them today, they said they can fix it and have fixed plenty of them even for Toyota and suspension manufactures, 2 week wait thow.
                          So I'll give my dealer a chance to rectify it first. Dissapointed they even returned the car as is
                          Phs
                            Yep standard kdss sway bar.
                            If you email me your number I will give you a call & you can try something.
                            Or wait 2 weeks & we will never know
                              The measurements are too high at the front. Passenger's side needs less preload, so the collar needs to go up.
                              If the coils are different side to side, then they may have got it the wrong way round. If you feel the wire thickness between the 2 springs, can you feel a difference?
