1KD Powered Up!!
  • 1KD Powered Up!!
    Hi All
    After owning my 2008 prado since new it was time to extract some power out of it.
    Mods consist of the following
    Upgrades as follows:
    - S2 GTurbo
    - 30% injectors (1KD)
    - 3" exhaust
    - GTurbo custom ECU tune
    - Front mount intercooler (This was a bit of a task to complete)
    - 4" stainless snorkel
    - Custom airbox
    Very happy with the result. Smooth and very responsive
    Results are - 156.5kW and 530Nm at wheels in 4WD - 70% power and 58% torque increase. 33" M/T tyres
    Tell them the price son!
      Originally posted by shanders View Post
      Hi All
      - S2 GTurbo
      - 3" exhaust
      - Custom airbox
      [ATTACH=CONFIG]25373[/ATTACH]
      Sounds like something for a SUBARU WRX STI.
      That would be nice to drive.
      Have you heard about the 1kd piston crack?
      May chuck a set of 110 or other upgraded pistons too.
      Good luck with it, really.
        That upgrade might end up not all it's cracked up to be... Groan
        Really though good luck
        adrian5800
        Last edited by adrian5800; 06-05-2017, 07:14 PM. Reason: It originally sounded too negative
          Hey Adrian5800
          Rough figure was $8K. Most of the cost was due to the intercooler piping and FMIC as there is not an off the shelf kit for the 1KD model. To do it all again with what I know now would be around the $7K mark. Was contemplating an upgrade to a 200 series but for the same power now for the fraction of the outlay speaks for itself.
          Shanders
            How have these mods affected your fuel economy mate.
              Hi All
              - S2 GTurbo
              - 3" exhaust
              - Custom airbox
              Have you fitted any instrumentation, EGT, boost, coolant temp?
              With all that extra tune, you may have just pulled the trigger on a 1KD-I.E.D.
              I hope it all goes well, don't wish to read about another blown (no pun intended) 1KD.
              cheers
              Steve
                nice gains, must be pretty good to drive. Hows the clutch holding up?
                  No issues withe the clutch on both dyno run and road. I reckon i would be wanting a heavy duty clutch around the 180rkw mark..
                    Here are some pics
                      hows it drive compared with a 200 series?
                        I forgot to mention, do you do any serious towing with it? Only reason I ask is that someone else on here had a wild tune and it started throwing fault codes when it was pushed when fully loaded; don't want to spoil a big trip!
                        Things change when you are pushing it in 40C heat, EGTs rise a lot quicker than most people imagine (me included). It was an eye-opener when I fitted up the gauges!
                          Hi t303
                          I haven't towed with it yet. I do own a camper trailer and when fully loaded is approx 1900kg. Only came out of the shop on Friday so haven't towed with it as yet.
                            Hey ejukated
                            To be honest i have never driven a 200 series so i can't compare. Currently the prado hits boost at 1800rpm and is just so smooth and responsive. Its a totally different vehicle to standard. Graeme from Gturbo knows his stuff when it comes to 1KD engines..
                              cool, looks fun to drive off the dyno charts. Cant wait to start tuning the 1KZ
