Kings 6 drive throttle controller 150 series v6
  • Kings 6 drive throttle controller 150 series v6
    Hi, well I found little info when I purchased this unit so thought I would kick off this for anyone interested. I purchased the unit for $99 with zero expectations. I have just been for a drive around an industrial estate while waiting to pick up my daughter from Gymnastics.. my review is, Get one, get one NOW.
    Makes the engine come to life, the way it should, so far in my 10 minute fury of start stopping etc, I like half acceleration, pulls with a bit more bite and a lot smoother and responsive. full acceleration mode is wild... as in overtaking I imagine would be soooo good.
    I think you hoons will get your grin on.
    Installation took me 5-10mins max
    Only bad point would be the double sided tape on the back of the unit... really low tack, I just put on some Velcro and sorted that... that is included in the 10 minutes.
    I am sure more people educated in this field will recommend settings etc, but for my first plug and play, I say hooray
    $99 well spent. Cheers
    So you made your throttle open faster with lest peddle for a $100, right.
    [/CENTER]
      Hey Symo, yeah sort of.
      If you don't like the accelerator lag... slight as it may be, this definitely makes it feel more responsive. I am impressed... and not technical, so was an easy thing to do
        I have another brand one on my 150 V6 for a couple of years and turn it off every now and then to remind me how bad the standard electronic throttle is. Mine was about $200 but money well spent IMO.
            Weird thing is, my mechanic drove one of his friends cars with one, then got one. Now recommends them highly. I'm not sure about them, tempted to try one
              How is the fuel usage after running this, any increase?
              I could be wrong but i'm guessing this changes the voltage relationship of the throttle position sensor, for example normally depressing the throttle 10% will apply 10% of the WOT voltage. But with this throttle controller, depressing the throttle 10% will apply 20% of the WOT voltage making acceleration come on a lot harder and faster.
              That's just my guess 4wdsupacenter doesnt say anything about how it works.
                  Originally posted by TCT888 View Post
                  I'd suspect the fuel usage would be the same as if you were to be a bit heavier footed than normal, BUT in saying that, its also reaches your desired speed ALOT faster, with a fraction of pedal movement, to which you then tend to only flutter the pedal to maintain speed as desired, so I cant see there would be much difference in economy, but that is yet to be seen.
                  Any update on your fuel usage?
                  95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
                  [/SIZE]
                    Can you clarify for me which unit you have installed? I have a 2004 120 3td. Also how did the fuel consumption go ?
                    Mick015
                      Also, which unit did you get? I just called them and they said that they don't do one for the 150...
                      [/SIZE]
