I have installed a solid kit dual battery monitor. I picked up an ignition source at the rear of the centre console for the main battery . This turns the main battery monitor off when the ignition is off. Good. I have power from my second battery for the aux but his stays on all of the time . Bad? Or does it draw so little power as to be inconsequential? I also have a spare New Pro Tech switch which I planned to use to turn the aux monitor off. The wiring diag it came with has it running throufh a relay but as I have a 3 amp fuse in there anyway I was planning to do without. The wires from it are: Green- Supply;Black- earth; Red/yellow- from relay. 86; Dash ligh- red/yellow [not to worried about this one].
The question is can I just put this in either the power or earth from the aux monitor as a simple on/off switch? If so , which wires where? If this is a no go I can simply put in a simple on/off switch into the power lead from the aux monitor? Thanks
