1999 toyota prado vzj95 v6 petrol i have got the lpg going its a apa tank with a airod converter there is no vac leaks it does idle abit high because of the iac needs cleaning but i have noticed that if you put the boot into it from lights it hesitate for a a second or 2 like its going to back fire through the airbox and it moves along and the previous owner has said it this in the add when i bought it on what happens so im hoping i can get some help on this
LPG system: likely needs plugs and leads as the LPG system can backfire or stall under load. Had same thing occur about 2 years ago, fixed for few a few hundred had been OK since, but have not attempted to fix this time as will leave for buyer. Not uncommon with LPGs, higher spark plug wear is price you pay for big savings on petrol bill. No issues with petrol side. You can just drive as a petrol car or fix lpg side, which should not be a huge issue. This factor is allowed for in the price.
Service history: In general have had anything fixed immediately when indicated, no breakdowns. Here are most of the service and repairs performed in in the past 3 tears.
25.2.2014 Rear brake rotors and pads, replace handbrake shoe, inlet manifold, service and tune.
17.4.2014 273,838km Replace right rear seat belt
4.6.2014 277,903km Replace complete hand brake cable assembly
14.8.2014 Replace exhaust manifold and gasket
23.09.2014 283,917km Replace radiator, thermostat and coolant
3.2.2015 291,190km Service / oil change, leads, plugs and calibrate LPG system
13.4.2015 294,691km 2 inner rack ends, wheel bearings
17.6.2015 Service / oil change
30.7.2015 300,315km Replace right front seat belt
15.8.2015 4x Michelin 265/70/16 Latitude Cross tires. Wheel alignment. I’m not certain of the exact distance, but they have about 12,000km on them and still have a lot of life left, maybe 75%
21.12.2015 307,302km Service / oil change
11.4.2016 Wheel alignment and rotation
22.2.2017 312,431km Front brake pads and rotors
i have replaced intake hose and coil packs i have checked the spark plugs and they are ACDelco Professional Platinum Spark Plugs and the spark plugs look fine this is the spark plug
