I'd like to put a switch in series with my solidkit dual battery monitor so it's not on all the time while driving. A push button style switch that fits a 150 series socket, like the Idle Up switch would be ideal. Has anyone used something like that?
LF Idle Up style push button
+1 for Aironboard
http://www.aironboard.com.au/store/p.../switches.html
They will even do custom switches for you if you ask
I've ordered a switch from Aironboard. They've got a good range.
Next I am looking for a rocker type switch to connect to the panel in the rear cargo area. I am installing some Narva USB and 12V power sockets (merit, etc) to the panel above the tyre jack compartment. I've got a momentary push button (from Jaycar) for a voltage metre, but I'd also like a switch in parallel to that so I can also keep the voltage metre on. Hopefully this Jaycar switch will do the trick. I need to find 20 mins to get to the local store to check them out.
