hi guys ive just received my lovely prado tx ltd in the uk from japan i now have problems registering it . the speedometer needs to be in mph but it reads in kmh how can this be converted . its my second attempt to get it to pass and there is not much knowledge of this jeep in the uk any help is very appreciated
land cruiser prado 150 urgent help needed kmh to mph
Hi,
Their are convertor units available that convert the pulses form the gear box to KPM or MPH etc, the
issue would be if the pulses are also used by other systems. You would probably need to install before
the speedo. I would suggest your first point of call should be a speedometer repairer, they might give
you some ideas.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Possibly a bit more expensive, but perhaps simpler. The whole speedo module can be removed in about 5 minutes so perhaps you can just change it with one from a wrecker? Its a really simple job with instructions available on this site.
Also be careful with the J word, you might Jinx yourself[B]Steve[/B]
Originally posted by krypto View PostPossibly a bit more expensive, but perhaps simpler. The whole speedo module can be removed in about 5 minutes so perhaps you can just change it with one from a wrecker? Its a really simple job with instructions available on this site.
i have tried to look for a used speedometer there is none available that are mph. is it not possible to change from the functions on the jeep from km to mph ?
I have no other suggestions. But I want to wish you good luck with both your Prado and your Jeep. It sounds like they both have the same issue? ;-)2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
2008 Jayco Dove Outback - "Davo"
Why not design a sticker to apply over the speedo. Maybe someone has already done it.
Very common when Australia moved from MPH to KPH
Does the odometer have to show miles?
Here you go, try this mob:
http://www.lockwoodinternational.co....-vehicles.html
Choose which model prado here:
http://www.lockwoodinternational.co....ser-prado.htmlLast edited by photoprado; 06-06-2017, 01:27 PM.2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
Originally posted by photoprado View PostWhy not design a sticker to apply over the speedo. Maybe someone has already done it.
In the UK I used a converter, called a Yellow Box from memory, to convert a motorcycle speedometer. You plugged it in and then it has micro switches that you set depending on the vehicle, if you've changed tyre sizes, and which way you wanted to convert.95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
[/SIZE]
EBay new custom made dial backs AU$99
http://www.ebay.com.au/itm/152257855707
Made to order apparentlySilver '04 KZJ120~Manual~GXL~Dobinson/Kings lift~Custom valved Ironmans~Detroit Locker~Endless Air~X9 Superwinch~Madman EMS1~TJM Dual Battery~Rhino Roof Tray~120W solar panel~Foxwing awning~Bushskinz UVP~Long Ranger water tank~Bushman fridge~Steinbauer P-Box~Beaudesert 2 3/4"~Airtec Snorkel~TJM Sliders~Prico Boost Gauge~BFG-KO2s~TPMS~GME TX3420~Front and Rear Cameras~Ultimate Camper hanging off the back!
