Wing Mirror not Resetting Properly
  • Wing Mirror not Resetting Properly
    My right hand wing mirror is not resetting in to the correct position. I banged it on the chimney at home reversing in a few months ago admittedly but it was working fine. The other day, it started folding further out (if that makes sense) every time I start it. If I hit the fold button, it pulls the mirror in, I hit it again and it goes too far out again. I cant get it to "centre" without manually pulling the mirror back a little but it seems loose. Any clues?
    Unfortunately it sounds like it's busted and an expensive replacement.
      Went to a Toyota dealer near work Sat morning, confirmed its cactus. $1050 for genuine replacement (with colour coded cover) plus $150 to fit. For the time being, I pulled the mirror off, pulled out the purple wire to isolate the folding module power supply to it.
        Got a second hand one in perfect condition, same colour for $700. Took the old one apart and found the offending broken actuator. I found one on here (same part number so should be the same):
        https://www.ebay.com.au/sch/i.html?_...+7381&_sacat=0
        Can also get a new indicator for $40 (non gen).
        I reckon it might be worth a punt trying to fix it. At worst, I'll have a spare.
          N you will be surprise it will work. Here prices are way too over for everything. E.g. I brought genuine toyota oil filter from USA $105 delivered(10 unit). Single cost here $35 from toyota. This is not just toyota BMW/Audi is same. So next time try to find part no google it you will find way to cheaper options.
            My door lock actuator stopped working, Toyota price $370, Amyama $170, ebay /alibaba $30, electric motor inside lock actuator $2 on eBay. The difficulty is finding part numbers.
            What sucks is that the door lock is not designed to be repaired, it's a throw away design and not that easy to pull apart. I hate the way everything is not designed to be repaired any more.
            [B]Steve[/B]
              This actuator looked impossible to take out also. The cables run through it and you think how the hell do take them out with cutting and re-soldering. But with abit of deep investigation and fiddling, I found out how to unplug the wiring harnesses and slide them through he actuator and remove it. Now to find the right part.
