Illumination wire under center console
  • Illumination wire under center console
    Does anyone know if there is a wire for the dash light illumination under the console where the gearshift is?
    Ciggy lighter isn't backlit, I'm thinking there must be as other models have center diff lock switches etc which would be backlit.
    Otherwise I'll pull it all apart and get stuck in with the multimeter
    If you want to run a wire from over near the key, you can tap into the back of the back light brightness plug. Cant remember the wire but can check for you.
    [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
      Cheers, I know the wire on that side - used it for my compressor switch. Was hoping not to have to run a wire over to there
        Found the wire, its the green one in the top row pictured below. I think its the connector used for the Height Control suspension in Grande Models
          Well done! - but what are you going to use it for?
          Rob.
            Originally posted by ejukated View Post
            Fitted 2x AUX usb ports/volt meters to the Main and Aux batt with a bypass switch. Switch allows the USB ports off the AUX battery to be turned on without the key in the ignition, the whole lot comes on when the key is on ACC or ON. Made up a loom to go with so the panel can be easily disconnected without getting the switch/USB ports jumbled up putting it back together.
            The wire is used for the backlight of the switch.
            http://www.pradopoint.com.au/showthread.php?31622-What-did-you-do-to-your-120-today&p=571718&viewfull=1#post571718
              just looking at the photos and was wondering how you put the uhf there. thanks for any info or pictures.
                sorry for never replying. if anyone's following, the remote head is screwed to the upper panel and the body is mounted to the passenger side upper kick panel (above the footwell)
