Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
  1. #13
    Lurker
    Join Date
    Dec 2015
    Location
    Czech Republic
    Posts
    10
    First I went to Independent service. Their statement is that the noise is coming from the top of the engine; Toyota said that they are not able to determine the exact pin-point of the noise.
    Independent service used stethoscope, not sure how accurate they were.
    Independent service said that new injectors are in normal parameters, valve clearance checked, engine compression is ok. These things were double checked by Toyota service.
  2. #14
    Lurker
    Join Date
    Dec 2015
    Location
    Czech Republic
    Posts
    10
    Does anybody know what is that stuff between injector and engine column?
    Toyota said that is something like a silicone, put by previous service.P1170599.jpg
  3. #15
    Join Date
    Aug 2008
    Location
    Brisbane, QLD
    Posts
    792
    Looks like silicon. Whoever took the rocker cover off got lazy and didn't replace the seal around the top of the injector.
    2008 GXL D4D + Option Pack 1, Safari snorkel, factory alloy bar, dual battery system, Lovells TFR-118/TRR119 Springs, Bilstein Shocks, Prodigy P3 brake controller, factory tow bar, Orac coupling.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
