fob batteries
  • fob batteries
    i am sure this has been addressed someone where but i am sick of looking for it . i have a 2014 GLX
    can some please tell me if you can remove the battery out of the fob for long periods (1year plus) and not have to get it reprogrammed ???
    hoping it is like a USB stick and the battery is only used to transmit the signal .
    my thought is to hide the mechanical key under the car and the disabled spare fob with battery inside the car, so if i loose a fob i am not stranded
    thanks in advance john
    My spare fob battery went flat for I have no idea how long. Changed battery and all good. I would imagine it is non-volatile memory otherwise it would forget its programming as soon as the battery went flat.
      I took battery out of mine for 7 months when off the road without any problems
        Fob and separated battery hidden inside car for two years. manual key taped and wired under car. Finally had to access when main key was temporarily lost (which was the whole purpose of the exercise). Opening car sets off alarm which cannot be stopped until you get it out and put the battery back in. Great solution when you are a long way from home. or pay $500+++ for a new key.
