Hydrogen engine carbon clean
  • Hydrogen engine carbon clean
    Hi all, anyone tried the engine carbon clean mob?
    Apparently they use hydrogen thru the air intake to clean the internals, would this be enough to clean out the egr and is there a risk of causing drama down the line by pushing chunks of the soot built up into the intake manifold, cylinder, turbo, exhaust etc?
    Think it would be wiser to manually clean the egr first somehow...
    Think "Hindenburg"
      A guy at work has two of these units, I was a bit of a guinea pig and we hooked them both up and gave it a go, twice after about a month apart, I have a 120 V6 did not really do anything. However he owns two diesels and has done many diesels since and they have had great results, he has described the amount of soot that comes out at the beginning to the end as surprising and instant drive-ability and MPG increases, so I guess if you have a diesel try it.
        Think I'll give it a shot, after I've cleaned out the egr first!
        Haven't got much to lose at this stage...
        Will report back in a month or so once done
          Hi Rijarth
          Did you end up giving this a go?
          I'm looking into it and trying to find any feedback is near impossible
            Snake oil... I know of an independent review that was done and it was proven to be of similar benefit to those electronic rust coupler/converter devices. Buyer beware as they say..
              All they do is spray water into the air intake.
              Michael and Kelly
              [SIZE=1]1999 Prado Snowy 3.4L petrol, Ultimate Suspension 50mm lift (2013)[/SIZE][SIZE=1], BFG A/T, bull bar, winch, Twine hot water shower, home made rear drawers, Shippshape car top tent, UHF radio, tablet GPS & Navman GPS (both running OziExplorer)[/SIZE][SIZE=1], Spot 1, solar panel, second battery, inverter, Engel fridge and more[/SIZE]
                Probably using DiHydrogenMonoxide to do the cleaning....
