Hi,
I have been attempting to get my rear air bags to sit level left to right with no luck
Prior to lift it was leaning about 10mm-15mm to the passanger side, straight after lift it was 15-20mm
After it all settled the front is spot on and the rear was 20mm lower to the drivers side
I spoke with airbag man they could only suggest packing the drivers side sensor another 6mm or so they also mentioned the airbags will force any KDSS lean out of there was Any ( doubtful as the front is good )
So I packed it out another 5mm and it raised the drivers side by 10mm so only 10mm from one side to the other
Now over 3-4 weeks it has gone back to 20mm ? There has to be something that is overriding the indevidual L and R sensors it's just to much of a coincidence for them to revert back to 20mm again
Any ideas ?
Any ideas ?
