Milkman,
Yes I have the Airbagman Kakadu 2" Airbag lift in the rear
There kit has longer bags and involves packing both left and right sensors further off the chassis using nylon packers / washers this does the same as sliding the bolt up. Both bolts are also at the top of there adjustment, as you mentioned the L and R readings from techstream have me scratching my head. As both sensors are in the same position, well within 2-4mm in favour of lowering the high passanger side
Amts,
that is the feeling I am getting with the sensors
Just odd given the information the airbag man engineer had given me over the phone, but After there recommendation to simply pack the drivers side sensor further did nothing, there engineer has failed to return my calls So every chance they have no idea.
Amts,
