Heath's 2016 150 Kakadu
    Looks great Heath, I am just starting to build my 2015 VX. With very similar shopping list. I went to order ARB Bull Bar, Side Steps and Rails - however they have advised the side steps are not compatible with the KDSS system ? DId you have any issues with this and was there a solution ? Any assistance greatly appreciated (do you know the part number for your side steps ?).
      Originally posted by Heath. View Post
      Local 4x4 Centre had a few specials at a Camping show.
      Recently installed
      2 Inch lift coming early next year.
      Looks great
      What lift are you fitting? I had ARB fit BP51s to our 2016 Kakadu
        Thanks. I am very happy with it.
        It was never mentioned to me that it would be a problem (However I remember some comment about some extra hours to make it work.) They moved the lights that where on the old steps onto the new steps. (Not sure if the VX has lights under the side steps however). I would try a different store (Mine was an independent 4x4 store who is an ARB distributor) or push the issue with them, show them pictures of my car with it installed and tell them to ring Inverell 4WD Centre on (02) 6721 2516 and chat to the guys about the problem. (Speak to Scott or Dwayne). I checked the invoice and it doesn't give part numbers sorry.
          Originally posted by Phs View Post
          Looks great
          Thanks. Yes going the BP51s. Same setup as you. Printed out your post and took it down. Thanks for posting that info and pic.
            Recently installed
            Pic with the new gear
              [ATTACH=CONFIG]26426[/ATTACH]
              Looks sweet AF. The ARB summit bar and rails look tough. Poor thing is totally dying for the lift now.
                Yes definitely. Going in next Thursday.
                  BP-51's and AirBag Man airbags installed last Thursday.
                  Very happy with the result. Thanks to Phs for his post that gave all of the info.
                    Hi Heath,
                    Happy it was useful info I just send you an email, if you need any info on setting up the Rear ride height or Damper setting for different terrain ect. just let me know, We had played around with ours along the way and we are happy with we're it is at.
                    Good luck and all the best.
                      Hi Heath,
                      Thanks Phs,
                      Got that. Appreciate it. Will respond shortly.
                        Finally got around to taking a picture with the suspension upgrade
                          What are your heights from the bottom of the rim to the bottom lip of the wheel arch mate? Looks great, by the look of it those rims are the 18inch option that you can get with the VX/kaka?
