ive decided im buying a 120 series petrol - is this good value?
  • ive decided im buying a 120 series petrol - is this good value?
    Hi Guys ,
    Tomorrow I'm going to look at a Grande
    its a 2006 Petrol Grande for $15900 with 197000KM with RWC and 7 months regs
    Wondering if you think its good value? or is that the going rate
    warm regards Steve
    Seems a little low if it was in Perth, but over east there is a lot more on the ground to choose from, I got mine with 166k on clock and went over it with a bright torch and inspection mirror to look for damage the great thing is since these have good clearance you can inspect underneath easily. I have a V6 Grande late 2006 it is fantastic drive, I replaced suspension pretty much after buying but retained TEMS/airbags got new parts from partsouq.com, but if it does not drive like new move on to next one these can feel like new for crazy kms if looked after. Good luck.
      Hi hobes, did you replace the springs and shocks at the front and the airbags at the back? Do you recall the cost ?
        Seems like good value. Check common wear items like the leather, sunroof for rust, airbags have no leaks, rear door seal for rust, cooler is cool, cv boots aren't leaking (plus others I'm sure other ppl may recall)
          thanks billz0r , ill go right through it
            Also check if it has the timing cover oil leak, (just by power steering pump) it was common for that year and mileage. Its a 2 k plus fix to get it done by toyota or a good day and a half on your own.
              thanks piggy
                Replaced the Tems shocks on front, airbags and new front springs C59-296 dobinsons. Back shocks where fine (looks like they where replaced not to long before I purchased it.) so two Tems front shocks $US 173 ea, airbags $US132 ea dobinsons springs where $au210 pair. Got some radiator hoses as well.
                  Thanks hobes , good to know if it's required
