2.8 6 Speed Auto flaring on up shifts.
  • 2.8 6 Speed Auto flaring on up shifts.
    Hi all, has anyone else experienced this issue ? Is does seem mainly when cold and only in the lower gears with moderate load.
    Yes, until I had the firmware updated that addresses the behaviour.
      Cheers, Mine is built 2017 (forgot to mention that) but it is January I shall go and see the dealership then.
        I had the same issue they did a software upgrade and it got better but it happen sometimes when cold
          Had mine done ages ago, appeared to fix for a while, but. Ow and again, first thing in the morning, it still makes occurs.
            Hi, I had the same problem. Mostly when cold, going from 3rd to 4th. I also suffered from occasional lack of power loss which i think was related to DPF. Anyway, re: gear flare. Toyota Replaced my gearbox, after about 12months of complaining. This didn't fix the issue. The service manager informed me that all 2.8 6sp auto combo's do this (Fortuna, Hilux? and prado). So eventually, I took it back to toyota, had them write me a letter saying that the car was mechanically sound, the slipping is normal and the DPF power loss is within specs. I never believed it so I sold the car, provided the letter as warranty to the new owner.
            Bottom line, this engine/transmission and DPF combo is not up to scratch, as far as I'm concerned.
