Power Window Problems staying up
  • Power Window Problems staying up
    Im having a problem with my RHR window it will not stay up. Stuck at half way.
    If you push up on the window switch it will go up and then back down to half way. If I push down it goes down and then back up to half way.
    This all a started after a flat battery.
    The only way to keep window up is to use the remote entry/key fob and do the window up or down trick with it. When I get it up it stays up. (Enter GIF here)
    Untill some one touchs the window switch again.
    Anyone ever seen this happen before?
    150 Prado D4D GXL Blue Storm, T13 TJM Bar, 265/70/17 Goodyear MTR Kevlar, Tigers11 1200 pound 2 speed Winch, Fox Shocks remote resevor, Air tec Snorkel, ARB Air Lockers Front and Back, Off Road Systems Draws with Drop Down Fridge Slide, Wetsuit seatcovers.
    On 120 series there were issues with power windows needing to be reset somehow after removing the battery, otherwise auto up/down might not work. There is a procedure in the owner's manual. Maybe something similar with the 150? Try this thread: http://www.pradopoint.com.au/showthr...ht=window+auto
    2008 D4D GX Auto, OP2 (traction/cruise/climate control), ARB deluxe bar, DominatorX winch, dual batteries, Whitey's 50mm lift, 265/70/17, UHF, King's 7" spotties, trans cooler
      Has any had this problem on a 150?
        I have just had the same issue with my Right back window also. Did you have the issue fixed, if so what was the problem?
          Sorry still the same.
            Have you tried going to a care reapir shop?
              Depends on your skills. Is this only on main sw at drivers door or both door switch?
              if both I'd say the limit switches in the door are dirty or faulty. U could try take door panel off and spray electric cleaner around switches.
              If only one dr sw faulty spray cleaner in it. I sprayed isopropyl in mine and it sorted all the issues out.
                if it is happening after the flat battery you will need to "reset' the window. in my case the auto function stopped working.
                use the switch to open the window, then hold the switch in the up position for another 15 seconds after the window closes.
                that is all.
