CTEK D250S DUAL DC/DC Charger
  • CTEK D250S DUAL DC/DC Charger
    SOLD.
    How do i delete this post?
    ITEM: CTEK D250S DUAL DC/DC Charger
    CONDITION: USED. Perfect working condition, with manufacturer warranty until 27 Sept 2017
    REASON FOR SELLING: Just purchased a winch, and want a high current connection between primary and secondary batteries instead.
    PRICE AND PRICE CONDITIONS: $180 ONO. Willing to post at buyers expense after full payment by paypal.
    PICTURES:
    EXTRA INFO:
    In perfect working condition. Has worked flawlessly for me under bonnet fully charging an 80 AH AGM in all conditions.
    Max 20 A charge current. Suitable for 12V lead-acid batteries (Wet, MF, GEL and AGM)
    Does not require a relay etc to work with V6 or most 3.0 Prados.
    CTEK Blurb:
    http://smartercharger.com/products/d...ek-d250s-dual/
    The CTEK D250S is a Premium Battery Isolator, a Smart Power Relay, Solar Panel Voltage Controller with MPPT solar power management functionality and a temperature compensated 20A smart battery charger all combined into one multi-functional product!
    The D250S DUAL on-board charger, charges while you drive; it gathers energy from multiple DC power sources (the alternator(s), solar panels and/or wind power generators) and optimizes power to properly charge your service battery bank with microprocessor controlled smart charging algorithms and provides temperature controlled charging to meet the charge requirements of your service battery bank in any weather. It increases simplicity and reliability by eliminating the clutter of many individual components including battery switches, secondary battery isolators, relays, load managers, low voltage alarms and cutoff’s, separate solar panel and wind generator voltage controllers, etc.
    The CTEK D250S Dual on-board charging system optimizes the charge generated during driving in order to provide you with more battery power and capacity when you need it.
    High Efficiency Power Management
    Suitable for all 12V lead acid batteries
    Simple to install and use – Fully Automatic
    Multi-step charging from alternators and other DC sources such as solar panels
    Automatic starter/service battery separation.
    Solar panel voltage regulator with Maximum PowerPoint Tracking (MPPT), synchronizes with other power sources such as alternator and/or wind generator
    Maintenance charge of starter battery via solar panel
    High vibration resistant design
    Features
    Multi-step charging from alternators and solar panels
    Battery separator that eliminates diodes and VSR relays
    Solar panel regulator with Maximum Power Point Tracking, synchronised
    with other current sources such as the alternator and/or wind
    Simplified installation of remote batteries for bow thrust of anchor winch
    Benefits
    Maximised battery life due to minimised undercharge time
    Maximised battery capacity when the battery is kept fully charged to avoid harmful sulphate crystals on the lead plates and stratification of the battery acid.
    Ability to take charge automatically from any power source that is connected to the CTEK D250S DUAL
    Reduced charging times and costs by decreasing engine idling and the dependency on AC power onshore through efficient use of alternator and solar power
    Reduced environmental impact through extended battery life and a reduced idle time
    Minimal installation time and cost
    Suitable For
    Boats
    Campervans and RVs
    Caravans
    4WDs
    Housing that rely on generators for extra electricity
    Compatible With
    CTEK Smart Pass
    Faster Charging
    The CTEK D250S Dual is a 5-step charger that automatically adjusts the charging voltage and current according to the battery state of charge and temperature – reducing a battery’s charge time. A sensor on the CTEK charger senses the battery temperature and adjusts the required charge by increasing the voltage in cold weather ensuring the battery is fully charged, and dropping the voltage in hot weather to avoid the problems of overcharging. With the CTEK D250S Dual , vehicle owners can be confident that their battery will always receive the optimal charging voltage, with reduced charge time and while ensuring the charging will be 100 % complete.
    Solar Connection
    The D250S Dual has the additional benefit of an auxiliary input which can be connected directly to solar panels without the need for a regulator, offering free power from the sun. D250S Dual has a built-in Maximum Power Point Tracker (MPPT) that helps the solar cells produce power as efficiently as possible by taking the most efficient source of energy from the solar panels automatically, and then using the power to charge the battery. The MPPT searches for the most effective combination of solar cell voltage and current, which ensures that the solar and alternator function in unison to maximize power output.
    Technical Data
    Spec Data
    Input Voltage 12.9 - 23VDC
    Charging voltage 14.4V (Temperature Compensated – Higher for cold, Lower for hot)
    Charging current Max 20A
    Type of charger 5 step, fully automatic charging cycle
    Type of batteries 12V lead-acid batteries (Wet, MF, GEL and AGM)
    Battery capacity 40-300Ah
    Insulation IP65 (splash and dust proof)
    Warranty 2 Year Limited Warranty
    Certification Meets ignition protection test requirements of the US Coast Guard stated in Title CFR 183.410
    Article Number 56-677
    Guaranteed Quality With CTEK
    CTEK offers a 2 year guarantee on all DC/DC chargers. CTEK customer support is an appreciated service, both with regard to general questions or specific issues related to charging and CTEK chargers. Safety, simplicity and flexibility characterizes all products and solutions developed and sold by CTEK. CTEK supply chargers to more than 60 countries throughout the world. CTEK is also a reliable OEM supplier to many of the world’s most prestigious car and motorcycle manufacturers. Contact customer support.
    drwormy
