Foam Cell Pro kit for my 150 GXL?
    Originally posted by Rdae1981 View Post
    I am in newcastle I got 60mm front and 70mm back. Sitting at 810mm front and 830mm rear front dropped 10mm as was sitting at 820 very happy so far by the time l add bash plates and a winch will be sitting at about 805mm. I got it installed for $1850 on interest free.
    Sounds great. Yeah, the front seems a little high. Wouldn't have a photo would you?
        From your measurements, the front is near 3" but the rear is right on 2".
          Are those 18" rims? The front does look higher than the rear.
          Nova
            Hey Amts my before measurements were 755 front and 760 rear
              Nova
              No only 17" it is a little higher in the front than l would have liked but will see how it settles and decide if l need to go a softer spring or maybe a diff drop.
                You need to wind down the spring seat by about 10mm. You want more droop/down travel.
                Your rear height is a bit low before you put in the new suspension.
                  Ok is that something that is relatively quick and easy to do? l am due to take it back this week to have a follow up inspection.
                    Can be done insitu of the threads had antiseize applied and the adjustment tool was used. Otherwise, the strut needs to be disassembled.
                      Ok thanks Amts will give them a call tomorrow and tell them what needs to be done
                        [ATTACH=CONFIG]25858[/ATTACH]
                        Thanks mate.
